Autocad 2017 Eğitim lisansını kurmaya çalışırken 4 5 defa bu sorunla karşılaştım 2016 yı denedim material library aşamasındayken ikisinde de sistem hata veriyo kurulum duruyo forumdaki tüm çözümleri denedim ama yine de düzelmedi sizce sorun ne?
2016/12/30:22:13:53 RABİANUR DESKTOP-9QNJNC2 === Setup started on DESKTOP-9QNJNC2 by RABİANUR ===
2016/12/30:22:13:53 RABİANUR DESKTOP-9QNJNC2 Path_Length: 162
2016/12/30:22:13:53 RABİANUR DESKTOP-9QNJNC2 Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2016/12/30:22:13:53 RABİANUR DESKTOP-9QNJNC2 Launch
2016/12/30:22:13:53 RABİANUR DESKTOP-9QNJNC2 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2016/12/30:22:13:53 RABİANUR DESKTOP-9QNJNC2 Current Directory C:\Users\RABANU~1\AppData\Local\Temp\_AI8D8C.tmp
2016/12/30:22:14:48 RABİANUR DESKTOP-9QNJNC2 === Setup ended ===
2016/12/30:22:13:54 RABİANUR DESKTOP-9QNJNC2 === Setup started on DESKTOP-9QNJNC2 by RABİANUR ===
2016/12/30:22:13:54 RABİANUR DESKTOP-9QNJNC2 Path_Length: 162
2016/12/30:22:13:54 RABİANUR DESKTOP-9QNJNC2 Current Directory C:\Users\RABANU~1\AppData\Local\Temp\_AI8D8C.tmp
2016/12/30:22:13:54 RABİANUR DESKTOP-9QNJNC2 Launch
2016/12/30:22:13:55 RABİANUR DESKTOP-9QNJNC2 Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/12/30:22:13:56 RABİANUR DESKTOP-9QNJNC2 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2016/12/30:22:13:56 RABİANUR DESKTOP-9QNJNC2 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/12/30:22:14:48 RABİANUR DESKTOP-9QNJNC2 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2016/12/30:22:14:48 RABİANUR DESKTOP-9QNJNC2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\RABANU~1\AppData\Local\Temp\_AI8D8C.tmp\Setup\AcSetup.dll
2016/12/30:22:14:48 RABİANUR DESKTOP-9QNJNC2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/12/30:22:14:48 RABİANUR DESKTOP-9QNJNC2 PageOpen LaunchDialog
2016/12/30:22:18:04 RABİANUR DESKTOP-9QNJNC2 PageOpen LicenseDialog
2016/12/30:22:18:04 RABİANUR DESKTOP-9QNJNC2 PageOpen ProductInfoDialog
2016/12/30:22:18:04 RABİANUR DESKTOP-9QNJNC2 PageOpen ProductSelectionDialog2
2016/12/30:22:18:15 RABİANUR DESKTOP-9QNJNC2 PageOpen FullProgressDialog
2016/12/30:22:18:16 RABİANUR DESKTOP-9QNJNC2 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/12/30:22:18:16 RABİANUR DESKTOP-9QNJNC2 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2016/12/30:22:18:16 RABİANUR DESKTOP-9QNJNC2 Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/12/30:22:18:18 RABİANUR DESKTOP-9QNJNC2 Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2016/12/30:22:18:18 RABİANUR DESKTOP-9QNJNC2 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2016/12/30:22:18:19 RABİANUR DESKTOP-9QNJNC2 Install Universal C Runtime (KB3118401) Succeeded
2016/12/30:22:18:19 RABİANUR DESKTOP-9QNJNC2 Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/12/30:22:18:26 RABİANUR DESKTOP-9QNJNC2 Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/12/30:22:18:26 RABİANUR DESKTOP-9QNJNC2 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\RABANU~1\AppData\Local\Temp\vcredist_x86_2015.log
2016/12/30:22:18:27 RABİANUR DESKTOP-9QNJNC2 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/12/30:22:18:27 RABİANUR DESKTOP-9QNJNC2 Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/12/30:22:18:34 RABİANUR DESKTOP-9QNJNC2 Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2016/12/30:22:18:34 RABİANUR DESKTOP-9QNJNC2 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\RABANU~1\AppData\Local\Temp\vcredist_x64_2015.log
2016/12/30:22:18:35 RABİANUR DESKTOP-9QNJNC2 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/12/30:22:18:36 RABİANUR DESKTOP-9QNJNC2 Download Play DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/12/30:22:18:39 RABİANUR DESKTOP-9QNJNC2 Download Complete DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2016/12/30:22:18:39 RABİANUR DESKTOP-9QNJNC2 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2016/12/30:22:18:45 RABİANUR DESKTOP-9QNJNC2 Install DirectX Runtime Succeeded
2016/12/30:22:18:46 RABİANUR DESKTOP-9QNJNC2 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/12/30:22:37:22 RABİANUR DESKTOP-9QNJNC2 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2016/12/30:22:37:22 RABİANUR DESKTOP-9QNJNC2 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2016/12/30:22:37:22 RABİANUR DESKTOP-9QNJNC2 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2016/12/30:22:37:22 RABİANUR DESKTOP-9QNJNC2 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/12/30:22:37:22 RABİANUR DESKTOP-9QNJNC2 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Çözüldü! Çözüme gidin.
TuncayBAKKAL01 tarafından çözüldü. Çözüme gidin.
Merhaba,
AutoCAD dosyalarını browser download yada aşağıdaki offline download ile indirip tekrar kurulum yapın.
http://autodesk.creativevirtual15.com/autodesk/bot
Download links / AutoCAD Products seçin
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
