AutoCAD Structural Detailing General DIscussion
jorgeluisg12
Message 1 of 10 (2,094 Views)
Z-profiles
2094 Views, 9 Replies
05-10-2011 10:55 AM
Where can I find/load Z-profiles into ASD database to use it as a purlins/girt profile?
Anyone know how to make connections between rafters/beams and laped Z-purlins?
Thanks.
The standard connection that I know near to what I see in your attached file is Purlin-rafter:
Select the macro: Purlin-rafter
Select rafter and press Enter
Select purlin and press Enter
Define connection
See the file joined.
Cheers,
Product Support
jad.dellel
Message 2 of 10 (2,053 Views)
Re: Z-profiles
05-26-2011 04:44 AM in reply to: jorgeluisg12
You've to add SADEF database for example.
See the pic joined.
Jad DELLEL
Structural Engineering Support Autodesk, Inc.
jorgeluisg12
Message 3 of 10 (2,047 Views)
Re: Z-profiles
05-26-2011 05:01 AM in reply to: jorgeluisg12
Hi Jad,
thanks for the reply and help me.
Do you have some standadr solution to connect purlins/girts with beams/rafters?
I've trying with a bended plate bolted in both sides.
Product Support
jad.dellel
Message 4 of 10 (2,043 Views)
Re: Z-profiles
05-26-2011 05:12 AM in reply to: jorgeluisg12
the bended plate bolted in both sides is the good one.
Jad DELLEL
jorgeluisg12
Message 5 of 10 (2,037 Views)
Re: Z-profiles
05-26-2011 06:13 AM in reply to: jad.dellel
Do you have another solution for this?
In the virtual event a few weeks ago Jack Johnson said to me that you have some videos to explain a bit more to use better these connections
Sorry but this a standard/automatic connection but I having problems to standarize this with ASD.
Please see in the attached.
Product Support
jad.dellel
Message 6 of 10 (2,021 Views)
Re: Z-profiles
05-27-2011 04:33 AM in reply to: jorgeluisg12
Define connection
Cheers,
Jad DELLEL
jorgeluisg12
Message 7 of 10 (2,017 Views)
Re: Z-profiles
05-27-2011 04:55 AM in reply to: jorgeluisg12
Thanks Jad.
Now it´s clear.
jorgeluisg12
Message 8 of 10 (2,013 Views)
Re: Z-profiles
05-27-2011 08:48 AM in reply to: jorgeluisg12
Sorry Jad,
I´ve  trying to connect a tapered beam to Z purlin but ASD dont recognozis the beam as a valid object.
In your example the hot rolled profiles are idetified as a valid member.
can you help me again?
New Member
steve.driedger
Message 9 of 10 (583 Views)
Re: Z-profiles
12-19-2013 12:05 PM in reply to: jad.dellel
Do you know if there is an Imperial database for Zee shapes?
Valued Contributor
jorgeluisgdeaca
Message 10 of 10 (559 Views)
Re: Z-profiles
12-20-2013 03:34 AM in reply to: steve.driedger
I'm sorry, many time ago I've moved from ASD to other programs that they are more flexible than this. I only use ASD for simple details.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
