AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
wrong hook placement
2 REPLIES 2
00alberto
505 Views, 2 Replies
Hi all,
i think there is another small problem when placing hooks for surface reinforcement bars.
If i select the 180 degree hook option, i have a hook configuration for the plan view (good) which is different from the configuration in the corrisponding position on the main reinforcement table (wrong)... the hooks  are placed on the opposite side (see attch)
2 REPLIES 2
Priitl220
in reply to: 00alberto
Could not get the same result. Hooks are fain at my model. You should post your file. Even better send it to Autodesk support- maybe its a bug.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
00alberto
strange... which version are you using?
i'm using asd2012 x64 with vindows 7. i also used a standard template, the italian one, but the same thing happens with other templates. See the dwg, still couldn't manage to get the hook placed correctly.
”Boost
”Tips
