I just installed ASD 2014 SP1 and now the Welcome Screen fails to appear.
"The Page You Were Looking for Was Not Found" message is displayed instead.
Anyone else experiencing this problem? My other Autodesk 2014 apps (ACA, ACE, ACM, LT, and P&ID) correctly display their respective Welcome Screens.
Jerry
Solved by Jakub.Brozonowicz. Go to Solution.
Pease try check what is the setting of key
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.1\ACAD-D030:409\WelcomeScreenFolder
There should be the link
C:\Program Files\Autodesk\AutoCAD 2014\Support\en-us\WelcomeScreen
The content of this folder should not be empty but like attached.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
The Registry Key does exist and contains the value shown.
The folder exists and the content matches what is in the ZIP file.
Ironically, ASD still fails to display the Welcome Screen. AutoCAD works as expected. Peculiar.
Let's consider this solution accepted. Thank you for your time and assistance.
Jerry
This does not fix my welcome screen in ASD exrension 2
please advise
thank you
