AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
989 Views, 1 Reply
Threaded hole?
Is it possible to make a threaded hole with ASD 2012? or is there any posibility to mark some holes as threaded hole? (automatical)
1 REPLY 1
I have not seen the option to have a threaded hole, however, I have used the bolt command to add in a bolt without a washer or nut and label it "PIN" in the description.  It doesn't change the image from having a hex head, but it is noted with the bolt and can be referanced in tags later.
Hope that helps.
”Boost
”Tips
