I have problem with displaying welds on technical drawing even though they are designed in 3d model. Probably I should search for solution somewhere in settings but after many attempts I still havent found.
Other thing is if it's possible to change tables styles on technical drawing i.e after generating drawing I have material bill in language other then English ( I have English version of ASD) so that I have to explode tables and correct every part manually. Moreover I have same problem with decriptions like Scale or Top view etc and table which is placed in right bottom corner of the window. Does anyone know how to solve those problems?
Best regards
These are 3 problems:
1) Welds apearing on drawings - Description styles - Settings or Adjusting Style.
2) English version of ASD lets you to open many language versions templates. But before job is started. Which exactly you need?
3) Please show such problems with descriptions. Is it problem with wrong placement?
All problems are connected with wrong decription language so instead of Scale I have Skala or instead of Title in right bottom corner table there is displayed Titre. Please find attachments
But which .dwt file is your rbcs-.... job template? (I think rbcs-048.dwt - Polish)
Which dwt fiel is template of drawings which you are generating? (rbcs-033.dwt - French?)
Yes, it was rbcs-048.dwt, how can I check and change dwt of generated drawings?
What number is for English template?
Thanks a lot!
@job template
English one is 044.
Look to Preferences -> Structural Detailing Tab in ACAD Options.
@drawing template
Format And Scales in Automatic Drawing Generation dialog.
