AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Table in template
6 REPLIES 6
mclarenforever
996 Views, 6 Replies
Table in template
Is possible to put a table in template when we create a automatic drawings with selected option (mode) Many Positions for some plates..?
I have seen that for an assembly with option Assembly and parts is possible to put the table in it.
Thank You.1.PNG2.PNG.!
6 REPLIES 6
Looks like not possible.
Added to wishlist.
Jakub Brożonowicz
Global Product Support
you can made it manually, using the table command after the automatic generation of drawing and selecting ("L" option) the views of the position that you want include in the table.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Thank you Jakub..! ( I wish )
Thank you Stefano..!
What do you mean with "L" option.?
Well, this is the procedure to insert a table in a many positions automatic created detail (plate, profile or subassembly is the same!).
1) You have to create an automatic drawing with many position (you do it well!);
2) After creation, you have a drawing like this:
3) Now, you have to select the "table command", in this case for plate, but you can use each type of table for each type of drawing (see picture below)
4) When you use this command in the layout tab, you can chose differtent element to be tabled: selected view, all or structure, you can select the "L" (in italian) option and select the plate that you want in the table (see the picture below)
And this is the final result, very easy and quick:
Greetings
PasProStudio
Thank you Stefano.!
Now is very clear.
Yes, only adding the table after the drawing generation.
Unfortunately auto-placing table not works for such action.
Jakub Brożonowicz
”Boost
”Tips
