When i produce a drawing from a group it always comes out as a 2d wire frame how do i change it to shaded with edges or something more 3d solid looking?
Solved by zcsillag. Go to Solution.
When I make an ISO drawing from a group I just right click on the document, then adjust style, then turn off invisible edges.
You can do shaded with edges from a group.
You would have to be in paper space and use the vport command like normal autocad. Then I guess your particular group would have to be on certain layers and then you could turn all other layers off in that particular layout.
That's the only way I know of that you could get shaded with edges, but even then I don't know if ASD would like it if you put profiles on other layers. It gets angry very easily.
