AutoCAD Structural Detailing General DIscussion
Active Member
Rick
Message 1 of 6 (1,429 Views)
Structural Detailing to Revit
1429 Views, 5 Replies
06-28-2012 12:35 PM
How do I link my Structural Detailing AutoCAD to Revit and link them so as the cad file changes it up dates in Revit?
What I would really like to do is export Revit to AutoCAD Structural detailing. Then detail the connections and reload back into Revit.
Distinguished Contributor
CristianLANCULESCU1367
Message 2 of 6 (1,398 Views)
Re: Structural Detailing to Revit
07-03-2012 12:44 AM in reply to: Rick
First of all, Revit doesn't import ASD detaills.
Second: The only workflow that really worked for me was:
Create structure in Revit -> Analyze it in Robot -> Update Revit ->Send to ASD -> Plot.
Revit has 2 types of connections in "Extensions":"Beam to column" and "Column end", while ASD has more then 30.
Regards.
Valued Contributor
jorgeluisgdeaca
Message 3 of 6 (1,387 Views)
07-03-2012 09:44 AM in reply to: CristianLANCULESCU1367
Cristian, you have worked with SDS/2 connections?
Message 4 of 6 (1,378 Views)
07-04-2012 01:25 AM in reply to: jorgeluisgdeaca
Hi Jorge,
I had an attempt, bu it didn't work in the first place. After that the trial has expired and I had to uninstall it. Anyway I'm receiving emails from them on a regular basis.  :smileyhappy:
OPINION:  FOR THE MOMENT I dont think I will buy it because:
1) Revit is not very precise for steel
2) I'm not an expert in Revit Structure
3) The SDS/2 is at the beginning
4) It doesn't have localized version (Romania).
My workflow is like this:
I make the model in Revit, compute it in Robot, make some schematic drawings (I don't know the english terminology, but they are plans in which I show the placement of columns, beams, foundations) and then send it to ASD for detailing and shop drawing.
Latelly I use Revit a lot, but i've started only 3 years ago...
The Revit Structure Suite also contains ASD. What I like is:
1) It has some macros (enough for regular buildings)
2) It is based on AutoCad plaform (I have more experience with it)
3) Positioning of elements and automatic drawings and annotations.
I will not place here the inconveniences of ASD.
Valued Contributor
jorgeluisgdeaca
Message 5 of 6 (1,372 Views)
07-04-2012 06:27 AM in reply to: CristianLANCULESCU1367
sure, I'm not an expert  using Revit too, only I want to know HOW accurately and flexible can be with steel structures, for this it's one step back to other specifics programs, but I believe this is the bussines of Revit, is an non specific program.
Message 6 of 6 (1,359 Views)
07-05-2012 12:25 AM in reply to: jorgeluisgdeaca
Revit is very flexible with steel, but not very accurate. At least not now.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
