I have a problem with ASD 2014. (sorry for my written english)
If I have a draw with two columns (1 and 2), that share a bar or the same type, for example the stirrup bars, if in Column1, I apply a multiple reinforcements because this colum1 appears 5 times, the programm automatically changes the bar type, a unless the column 2 also repeat 5 times too.
They can not be both stirrups with the same type, although one of them is repeated 5 times and the other 1.?
thanks for your help.
Solved by Artur.Kosakowski. Go to Solution.
Try to create elements (see the attached picture).
