AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Steel Knee/Fly Brace - South African Section Problem
8 REPLIES 8
Message 1 of 9
cashansa
1873 Views, 8 Replies
Good day All
I am having a problem creating a knee brace with the following macro:
rbct_mmacro Library name: StrBrace Class name: StrBraceCreate
(i.e. in the parametric structures tab - 2nd icon from top left - Toolbar: Parametric > Brace .)
It says it cannot create the brace with the section used ( ZA - CC - 150 x 50 x 20x 2.0). What could be the error?
I have atttached a file for your perusal.
Kind Regards
8 REPLIES 8
Message 2 of 9
Artur.Kosakowski
in reply to: cashansa
The connection macros 'filter' sections by their types. In this particular case the cold formed channel type is not included in the supported section types for purlins. I have added the request  for adding this type to the supported profile types for this connection type to the wish list for next versions of ASD.
You can try the following workaround:
1. Replace the CC section with another 'standard' channel
2. Generate connection using the macro
3. Explode the connection
4. Replace the standard channel with the CC section
5. Weld plates to the profile
Artur Kosakowski
Message 3 of 9
cashansa
Thank you for attending to the issue. I can create the brace manually, however, it so much easier if a macro executes the task.
I have read that Tekla allows the user to create a connection and copy it to other sections of the structure. If you could please request a similar feature to this in ASD, I would greatly appreciate it.
Thank you
Message 4 of 9
jorgeluisgdeaca
Many people says "Tekla can...Tekla do..". If Autodesk put many time and some $$$ maybe ASD can do  some things like Tekla. This is a custom component made in 30 seconds. In ASD not all profiles are available to do this. I've tried to do this in ASD three years ago, no succes. Still today i can't.FB.jpg
Message 5 of 9
ZHUKOV_ING
and 5 years later you can't do this in asd, i lost my nervs so one and a half year i am switched to Advance steel, and with graitec's software you will be able to do this connection.
😄 Greetings
Message 6 of 9
YEP,  many programs needs to know some information like grid location, level or coordinate to do this. I'm not talking about great BIM program, just good and simple programs.
 FLANGE BRACES:
*Surf
* Id   No.  Loc  Type  Offset  Opt  Ref
Message 7 of 9
cashansa
in reply to: jorgeluisgdeaca
Good day all
Thank you for the input.
It seems as if the ASD steel module cannot compete with the other packages on the market? However, we are a consulting engineering service. We had purchased the building design suite ultimate (for Robot and ASD-Reinforcement). These two work well, and I thought of giving ASD-Steel a try since it comes with the suite. When the package does come up to standard, after some customer feedback and criticism, I think we will have a very competitive product..
By the way, this suite is the cheapest all round structural engineering package on the market.
Regards
Message 8 of 9
Artur.Kosakowski
The support of these sections has been added in SP1 for ASD2104.
Artur Kosakowski
Message 9 of 9
zcsillag
in reply to: Artur.Kosakowski
Nice...now when bought Graitec ?
Why need SP1 ... Advance Steel more stable 😛
Delete ASD and change Building design suite content !!!
Regards
Csillag Zoltán
”Boost
”Tips
