AutoCAD Structural Detailing General DIscussion
Valued Contributor sta
Valued Contributor
sta
Message 1 of 6 (1,363 Views)
Steel Beam to Concrete Wall Connection- Revit Export and ASD difficulties
1363 Views, 5 Replies
11-08-2012 07:54 AM
What I am trying to do is create a 3d connection of a steel beam to concrete wall. Since that can not be done in Revit I exported to ASD. So I used the SAD Revit Extension I used the "Steel Detailing Link" to get my Revit steel into ASD. The concrete walls did not show up when doing this, so I used the "Formwork Drawing links" which gave me the walls I needed. However I can not figure out how to combine the two to make the connection. Also when I create this connection in ASD, how do I get it back into Revit? How will it appear?
Thanks!
Valued Contributor
jorgeluisgdeaca
Message 2 of 6 (1,357 Views)
Re: Steel Beam to Concrete Wall Connection- Revit Export and ASD difficulties
11-08-2012 11:13 AM in reply to: sta
Valued Contributor
sta
Message 3 of 6 (1,337 Views)
11-09-2012 06:27 AM in reply to: sta
Thanks for your reply. That link does not really help as my question deals with the exporting and importing of the project. That link appears to be the next step. Unfortunately I am not very familiar with ASD and the link posted goes over my head and creates more questions. Thanks again
Valued Contributor
jorgeluisgdeaca
Message 4 of 6 (1,325 Views)
11-09-2012 12:08 PM in reply to: sta
if you are triying to create a connection of a steel structure to concrete wall  based on a exported model from revit you can't export both steel and concrete. The posted link is only to know that concrete walls must be "faked" because ASD steel module does not support concrete walls.
Valued Contributor
jorgeluisgdeaca
Message 5 of 6 (1,319 Views)
11-09-2012 01:03 PM in reply to: sta
also Revit only has one extension with four connections, if you want to have more you must to obtain/pay for them, to SDS/2 for example.
Active Contributor
talles.projetos
Message 6 of 6 (540 Views)
10-02-2013 12:06 PM in reply to: jorgeluisgdeaca
The SDS / 2 works in revit with ASD? Type 100% functional. Anyone know if it works?
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
