AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
spiral stair tread
4 REPLIES 4
tpham2001
883 Views, 4 Replies
spiral stair tread
Hi All,
I created a spiral staircase and everything seems to worked well. I used 4" sch40 post and 3/4"x14"x14" BP. Hieght between floor is 12-5 1/2", this gives me 21 equal treads (which work out to 0'-7" riser). The question is the tread itself, I selected the follow tread from the pull down menu.
In the model this tread measured as it should be, but when I pulled dim in Edition Layout, this is what I have. The spiral stair radius is 3'-3" plus change...
What am I missing? How can something that is 3' wide grew to 78'? I looked in dim format - scale factor is 1. Can anyone shine some light and show me the way?
Also, are all the steps listed in pull down menu off the shelf item?
4 REPLIES 4
zcsillag
in reply to: tpham2001
Idk, but u use imperial units and treads metric ?
Regards
Csillag Zoltán
tpham2001
in reply to: zcsillag
Theses are all that I have, I don't have imperial treads even when I create a simple stair case, all treads came in as metric. Fortunately I have good relationship with my contractor, they said to give them the stringer and width layout and they do the rest.
This is part of the frustration which I can not figure it out. My Project Preferenes setting are in imperial yet these kind of things comes in as metric. There is a disconnection somewhere I don't know where to look.
zcsillag
"Theses are all that I have, I don't have imperial treads even when I create a simple stair case, all treads came in as metric" ...
So ASD team WHY ????
Regards
Csillag Zoltán
tpham2001
There are two data base available:
  1. UP_step_spiralHMS.xml
  2. UP_step_spiralMOSTOSTAL.xml.
Yes, both are in metric as I've disco.
But then I think all UP_step[xxx] data base are in metric.
So, ASD Team, what do you say? Think we end users can get an imperial version of these data base?
”Boost
”Tips
