AutoCAD Structural Detailing General DIscussion
Valued Contributor
ZHUKOV_ING
Message 1 of 7 (307 Views)
solid foundations in ASD-Steele
307 Views, 6 Replies
01-10-2012 05:54 PM
Why we should draw our foundations in separate file with ASD-Framework and then importing them in ASD-Steele 2012, i think it will be much easier if we have option to draw these elements directly in Steele module, so my suggestion is: if it's possible, autodesk developers to think about joining  theese two modules.
Best regards
Valued Contributor
ZHUKOV_ING
Message 2 of 7 (306 Views)
Re: solid foundations in ASD-Steele
01-10-2012 05:58 PM in reply to: ZHUKOV_ING
Also the option for creating section cuts in formwork module is very very useful, in steel module we should create group and then we can create section cut.
Best regards
Valued Mentor
ybogdanov
Message 3 of 7 (269 Views)
01-17-2012 12:06 PM in reply to: ZHUKOV_ING
one question, how do you import to steel? Recognize all information?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Valued Contributor
ZHUKOV_ING
Message 4 of 7 (265 Views)
01-17-2012 04:53 PM in reply to: ZHUKOV_ING
option is available  only  in ASD 2012 but first you should save your formwork drawing as acis solid in separate file
Valued Mentor
ybogdanov
Message 5 of 7 (261 Views)
01-17-2012 11:41 PM in reply to: ZHUKOV_ING
Could you said me the name of the option, please. I don't find it.
Yury Bogdanov
Barcelona (Spain)
Valued Contributor
ZHUKOV_ING
Message 6 of 7 (256 Views)
01-18-2012 01:28 AM in reply to: ybogdanov
It's under tools menu.
Valued Mentor
ybogdanov
Message 7 of 7 (247 Views)
01-18-2012 03:17 AM in reply to: ZHUKOV_ING
But with this options the formwork don't recognize information. It will be only 3D solid, no? And if it's send to ROBOT don't recognize the formwork objects?
Yury Bogdanov
Barcelona (Spain)
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
