AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
solid foundations in ASD-Steele
6 REPLIES 6
ZHUKOV_ING
667 Views, 6 Replies
Why we should draw our foundations in separate file with ASD-Framework and then importing them in ASD-Steele 2012, i think it will be much easier if we have option to draw these elements directly in Steele module, so my suggestion is: if it's possible, autodesk developers to think about joining  theese two modules.
Best regards
6 REPLIES 6
ZHUKOV_ING
in reply to: ZHUKOV_ING
Also the option for creating section cuts in formwork module is very very useful, in steel module we should create group and then we can create section cut.
Best regards
ybogdanov
one question, how do you import to steel? Recognize all information?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
ZHUKOV_ING
option is available  only  in ASD 2012 but first you should save your formwork drawing as acis solid in separate file
ybogdanov
Could you said me the name of the option, please. I don't find it.
Yury Bogdanov
Barcelona (Spain)
ZHUKOV_ING
in reply to: ybogdanov
It's under tools menu.
ybogdanov
But with this options the formwork don't recognize information. It will be only 3D solid, no? And if it's send to ROBOT don't recognize the formwork objects?
Yury Bogdanov
Barcelona (Spain)
”Boost
”Tips
