AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Single Tubular Bracing
5 REPLIES 5
RyanBotha
1712 Views, 5 Replies
I want to create a single piece of tubular bracing, with gussets on either end. See the attached image for the bracing centre lines. What is the best way to achieve this?
Thank you
Ryan
5 REPLIES 5
Check the movie.
Generally it needs to be specified as NOT Crossed bracing in Diagonals tab.
Jakub Brożonowicz
Global Product Support
Great! Thank you for the reply.
daniel.tansey
in reply to: RyanBotha
any luck I can do this with a W beam at the middle to the cross bracing with a gusset plate on top and bottom rather than the gusset in the middle. It seems that the cross bracing tool is not what i need, but i figured i would ask.
grfkpc
in reply to: Jakub.Brozonowicz
hi;
i am not create this bracing in asd.
there was a way to tihs ?
Thanx.
vanvan11
in reply to: grfkpc
yes
form long time i dont use macro for bracings
”Boost
”Tips
