AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Set ASD Steel elevation mark in meters instead of mm.
3 REPLIES 3
Priitl220
1031 Views, 3 Replies
Elevation marks are in mm (for example +4500).
How to make them show in m instead (for example +4,500)?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
3 REPLIES 3
It is set on mm.
No way to change the unit now.
Jakub Brożonowicz
Global Product Support
Valensas
in reply to: Priitl220
I need the same thing
Priitl220 have you ever seen anywhere elevation mark in mm? why is it set to mm and no way to change? 🙂
I have 150 drawings to change marks from 1300 to 1.300 manually now 😄 nice!
zcsillag
”Boost
”Tips
