AutoCAD Structural Detailing General DIscussion
Valued Contributor
Priitl220
Message 1 of 4 (577 Views)
Set ASD Steel elevation mark in meters instead of mm.
577 Views, 3 Replies
02-08-2013 03:04 AM
Elevation marks are in mm (for example +4500).
How to make them show in m instead (for example +4,500)?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Product Support
Jakub.Brozonowicz
Message 2 of 4 (569 Views)
Re: Set ASD Steel elevation mark in meters instead of mm.
02-08-2013 07:51 AM in reply to: Priitl220
It is set on mm.
No way to change the unit now.
Jakub Brożonowicz
Member
Valensas
Message 3 of 4 (362 Views)
08-02-2013 05:48 AM in reply to: Priitl220
I need the same thing
Priitl220 have you ever seen anywhere elevation mark in mm? why is it set to mm and no way to change? :smileyhappy:
I have 150 drawings to change marks from 1300 to 1.300 manually now :smileyvery-happy: nice!
zcsillag
Message 4 of 4 (340 Views)
08-03-2013 12:33 PM in reply to: Priitl220
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
