AutoCAD Structural Detailing General DIscussion
Active Contributor
emmar0001
Message 1 of 4 (301 Views)
Rounding off dimension problem
301 Views, 3 Replies
02-28-2014 07:21 AM
I'm having a problem with ASD and the roundoff command for dimensions. I have the dimstyle set to round off to the nearest 5 (mm). When i snap the dimension lines, it shows the figure as rounded off, but when I insert the same dimension line, it reverts back to the figured value (without rounding).
Can anyone help?
C3D 2010
Intel Core 2, Windows XP
2.67GHz, 3GB RAM
xSmiffyx
Message 2 of 4 (292 Views)
Re: Rounding off dimension problem
02-28-2014 07:44 AM in reply to: emmar0001
Hi
When you SNAP the dimension lines I take it you are placing the dim line between two points?
What do you mean by inserting the dim line, please explain.
"Please Mark "accepted as solution" if this solved your question and give KUDOS"
Active Contributor
emmar0001
Message 3 of 4 (282 Views)
02-28-2014 10:50 AM in reply to: xSmiffyx
Hi - yes when I mean snap to two points to show the dimeneion, but before I actually click again to position the dmiension.
C3D 2010
2.67GHz, 3GB RAM
jivkomitev2
Message 4 of 4 (230 Views)
03-06-2014 01:49 AM in reply to: emmar0001
ASD overiddes each dim text "by hand" after placing the dimesion. i think you can't set rounding
Post to the Community
New Post
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
