AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Rounding off dimension problem
3 REPLIES 3
emmar0001
549 Views, 3 Replies
I'm having a problem with ASD and the roundoff command for dimensions. I have the dimstyle set to round off to the nearest 5 (mm). When i snap the dimension lines, it shows the figure as rounded off, but when I insert the same dimension line, it reverts back to the figured value (without rounding).
Can anyone help?
C3D 2010
Intel Core 2, Windows XP
2.67GHz, 3GB RAM
3 REPLIES 3
xSmiffyx
in reply to: emmar0001
Hi
When you SNAP the dimension lines I take it you are placing the dim line between two points?
What do you mean by inserting the dim line, please explain.
"Please Mark "accepted as solution" if this solved your question and give KUDOS"
emmar0001
in reply to: xSmiffyx
Hi - yes when I mean snap to two points to show the dimeneion, but before I actually click again to position the dmiension.
C3D 2010
2.67GHz, 3GB RAM
jivkomitev2
ASD overiddes each dim text "by hand" after placing the dimesion. i think you can't set rounding
”Boost
”Tips
