AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Rounded Plate and bolts
2 REPLIES 2
JohnHolder
877 Views, 2 Replies
I am trying to add bolts to a steel tank structure, and I am sure there is a faster more efficient way ( I hope ) to do this.
I have added a render of the tank with some bolts in it.
Each panel is bolted together ( shown )
and angles offset bolted to the panels ( shown with partal bolting )
Currently I have had to rotate the entire model, then add bolts/holes
for each of the panels, which wasn't too bad.
but for the angles... each angle has 21 holes and there are 8 angles, and rotating the model
168 times and adding a couple bolts ( top and bottom angles ) is just not good.
I have tried coping bolts but they do not rotate.
any ideas?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
2 REPLIES 2
JohnHolder
in reply to: JohnHolder
Unfortunatly to keep all the 'intelligent' data, I have to rotate the model for each bolt...
Master Yoda.
Priitl220
If there is a repetitive detail, I usually add bolts to that element and copy that element with bolts around. Then I just use adapt bolts.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
”Boost
”Tips
