AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Message 1 of 8
992 Views, 7 Replies
Roof X bracing
Is possible to add roof bracings?
Web help only shows column bracing as valid option?
7 REPLIES 7
Message 2 of 8
Tony_Gibbs
Yes it is possible to add roof bracing and it works real good
It is a bit complicated to explain in this forum but very easy once you have got it.
I could help you out through remote desktop if you are interested
Email me at tony@ztechdrafting.com.au.
Message 3 of 8
Hi there. I have problem with the X-roof bracings. Could you show me the procedure? Thanks anyway
Message 4 of 8
Jakub.Brozonowicz
Please check attached movie.
Is this what was requested?
Jakub Brożonowicz
Global Product Support
Message 5 of 8
in reply to: Jakub.Brozonowicz
Thanks a lot mate!!!
Message 6 of 8
Jakub.Brozonowicz
If you find your post answered press the Accept as Solution button please.
This will help other users to find solutions much faster.
Thank you.
Jakub Brożonowicz
Message 7 of 8
haydenwse
Warning, beginner question.
How do you create the auxiliary bracing lines?
Message 8 of 8
in reply to: haydenwse
Draw 2 lines with line command. polyline does not work in 3D (use 3dpoly instead)
”Boost
”Tips
