Dear All,
Transfer Revit Model by REVIT Extension -> ASD->Steel Detailing Link as attached image,
Which macro used to new a connection for vertical brace to connect column and base plate ?
Which macro used to new a connection for vertical brace to connect column and girder ?
I assume that you do not want to use the bracing macro(?)
Then you can use truss connection between columns and braces.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
