In case you guys didn't notice, I'll point it out.
There is a button that points out to Autodesk that we want an answer from them.
Solved by DarrenP. Go to Solution.
this only applies to certain people
DarrenP
Thanks Darren. Seeing that made me investigate a bit into what I actually have for support. I didn't realize I had a fairly large support package.
I'll be trying out that phone support today.
you should be able to access it here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18146329&linkID=9240617
the wording from the previous post has changed
its no longer called gold & platium it has changed now
for previous gold subscription it is now called Advanced
platnium is now called enterprise
DarrenP
