Hi.
How dou you remove a drilled holegroup? I have a structure that is bolting together with a bridge. The bridge however is in a separate project so i have made holes in the first structure in the right places. But now the alignment is off due to some changes on the bridge. Can i alter the holes/drilling? Or remove and add a new group?
Thanks.
Solved by Jakub.Brozonowicz. Go to Solution.
Check attached movie how it might work.
please I know this an old thread but I can't open the video!
how do I remove unwanted drilled holes. they were for a connection that ws changed but the holes remained.
