In the reinforcement module there is the possibility to add some steel profiles (although without connections). I found it very useful.
But so far i couldn't find a way to get a steel profile table, anyone knows how to do it? There is a steel profile table style, and i can modify it, but after that how can i insert the steel profile table in the drawing?
Solved by Priitl220. Go to Solution.
1. define element (steel should belong to an element) via "element manager"
2. from elemets table RMC and select "steel table" (see attachment)
