AutoCAD Structural Detailing General DIscussion
Valued Contributor
3 Kudos
Post 1 of 5
Accepted Solution
Reinforcement length in ASD 2013
963 Views, 4 Replies
10-25-2012 06:33 AM
Please help!
I want to change the maximum length of the rebar from 12m to 11.7m:
when I use command Reinforecment Elevation and try to set a single bar with a length of 40m (or smth like that) I am dealing with a dilemma: ASD tries to cut it in bars with 12m each.
On interface you can only steer one bar only by MOD_BAR_LAP (Lap splices in Modify).
In database it is up to the diameter bar so many of MaxLength to change is needed.
Product Support
33 Kudos
Post 2 of 5
Re: Reinforcement length in ASD 2013
10-25-2012 08:28 AM in reply to: Ievgen
MaxLength value in bar_??? database is set on 12.
(C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Reinf)
Jakub Brożonowicz
Valued Contributor
3 Kudos
Post 3 of 5
10-25-2012 08:40 AM in reply to: Jakub.Brozonowicz
please specify what exact parameter I need to change. Is it possible to change with the ASD interface?
Product Support
33 Kudos
Post 4 of 5
10-26-2012 03:25 AM in reply to: Ievgen
Jakub Brożonowicz
New Member
0 Kudos
Post 5 of 5
04-11-2013 06:56 AM in reply to: Jakub.Brozonowicz
I want to change the max length to 6m. but it can't be done in the interface as mentioned above. couldn't either edit the source cords. pls clearly mention what should I do?
Post to the Community
New Post
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
