AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Reinforcement length in ASD 2013
4 REPLIES 4
Ievgen
2524 Views, 4 Replies
Please help!
I want to change the maximum length of the rebar from 12m to 11.7m:
when I use command Reinforecment Elevation and try to set a single bar with a length of 40m (or smth like that) I am dealing with a dilemma: ASD tries to cut it in bars with 12m each.
4 REPLIES 4
Jakub.Brozonowicz
in reply to: Ievgen
MaxLength value in bar_??? database is set on 12.
(C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Reinf)
Jakub Brożonowicz
Global Product Support
Ievgen
in reply to: Jakub.Brozonowicz
please specify what exact parameter I need to change. Is it possible to change with the ASD interface?
Jakub.Brozonowicz
in reply to: Ievgen
On interface you can only steer one bar only by MOD_BAR_LAP (Lap splices in Modify).
In database it is up to the diameter bar so many of MaxLength to change is needed.
Jakub Brożonowicz
I want to change the max length to 6m. but it can't be done in the interface as mentioned above. couldn't either edit the source cords. pls clearly mention what should I do?
”Boost
”Tips
