I use ASD 2013 and when I want to create connection between two rectangular beams, the program said that "Does not meet criteria".
I have one column 150x50mm and the perpendicular beam 100x30. I want to joint it with plate connection. It's posible to do?
Works fine for me. Are they European profiles (TCAR 150x150 and TREC 100x30)? Because I can't find the 100x30 rectangular.
What type of connection are you trying to do?
For example, TCAR 100x5 y TCAR 150x5 where the column (vertical beam) is TCAR 150 and horizontal beam TCAR100. After this I intent use "End Plate - Beam/Coumn flange" and the program is not open the window of macro.
