Hi everyone,
Recently I got an ASD drawing file from my client, but when I tried to open the drawing using ASD, I got an error stating that the RBCS-079.dwt cannot be found. I've check in the preference>structural detailing, RBCS-079 is not available in the drop down list. It is also not available in the template folder. I understand that this template is assigned for Ukraine, but in reinforcement, RBCR-079 do available.
Please refer picture for reference.
Anyone know how I can get the template?
Thanks everyone.
Solved by StefanoPasquini6790. Go to Solution.
Hi Stefano,
Thank you for your reply. But I do not have any previous version of ASD, hence I do not have any template. Do you have any idea where I can download the template? Tried to find it on the net, but couldn't find it. Really appreciate your helps.
Thank you.
if you haven't a previous version of rbcs-079.dwt you have no chance to find it, this mean that not exist.
My suggestion is to create your own template that contain all the settings that you want to use in your default ASD Steel drawing as, Dimension Style, Layers, Family, Profiles, and so on....
Spend one or two days to save your settings in your template file and don't forget that you can improve it whenever you want, try to start from another existing dwt.
Good luck and let me know if it work.
Thanks for your prompt reply. I've contacted my client to provide me the RBCS-079 template file and paste it into the template folder and it worked! How can I not think about that.
Thanks again Stefano!
