AutoCAD Structural Detailing General DIscussion
Active Member
jvnieuw
Message 1 of 6 (576 Views)
problem with reinforcement positioning
576 Views, 5 Replies
01-07-2014 09:09 AM
Hi all,
when working in Autocad Structural Detailing 2012, I have encountered a problem with reinforcement positioning.
Whenever I adjust an existing block in the drawing, from that moment on, I can create two different
reinforcement bars and still give them the same position number. Wich isn't exactly the point of numbering bars.
Can anybody help me out?
Apparently deleting the modified block and purging it, solves the problem: after saving, closing and re-opening the dwg, the numbering is back to normal.
If I have to change an existing block in the future, I will have to do it in regular Autocad and then copy-paste it in ASD.
Not a real solution, but it works for me :smileywink:
Product Support
Jakub.Brozonowicz
Message 2 of 6 (559 Views)
Re: problem with reinforcement positioning
01-07-2014 03:13 PM in reply to: jvnieuw
I am not sure about the sequence of operation that you described.
Is this the problem on specific file all common for the all your efforts?
Could you please let us know any more about this?
Jakub Brożonowicz
Active Member
jvnieuw
Message 3 of 6 (553 Views)
01-08-2014 12:06 AM in reply to: Jakub.Brozonowicz
This is what happens:
1. I create a reinforcement bar
2. I copy the bar for multiple usage in the drawing
3. I create a block or I import a block and adjust it (this has nothing to do with the reinforcement itself, I just need a certain block in the drawing)
4. When I change one of the copies of the bar, for instance I make it 100cm longer, the positioning does not change although it isn 't the same bar anymore.
I've uploaded a printscreen and the .dwg to illustrate the problem.
Thanks for you response!
Active Member
jvnieuw
Message 4 of 6 (545 Views)
01-08-2014 01:06 AM in reply to: jvnieuw
For the record:
This happens in all the drawings I make in ASD2012.
Removing the block and purging it doesn't help either. Once a block is created/adjusted the problem stays.
Product Support
Jakub.Brozonowicz
Message 5 of 6 (480 Views)
01-13-2014 03:50 PM in reply to: jvnieuw
If I just only go to modify the item it changes onto the length of other with same position but is the current version.
Do I understand that 2012 error is this case issue and you are looking for kind of solution for this version?
Jakub Brożonowicz
Active Member
jvnieuw
Message 6 of 6 (373 Views)
02-11-2014 03:07 AM in reply to: Jakub.Brozonowicz
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
