dear all
kindly find attached the 3 outputs of the same beam.
In dxf output and ASD output ,the beam is not the same as in robot output.
Please advise.
Solved by Sigo17. Go to Solution.
Solved by Jakub.Brozonowicz. Go to Solution.
What you mean by "not the same beam"?
I see some reinforcement differences but nothing critical in it.
dear sir
i mean the reinforcement of beams is different, why ?
,what option i have to do for best exporting between robor and asd.
regards
Any chance for getting the RTD file to test?
Facing some problems too.
What is the RSA template that you used? I'm finding very dificult to find a template that shows all the beam elevation in one sheet (all spans including cantilivers) and sections in the same layout.
Thank You,
Sílvio Gonçalves
