AutoCAD Structural Detailing General DIscussion
Valued Contributor
rodainnajjar1229
Message 1 of 5 (897 Views)
problem( robot to asd)
897 Views, 4 Replies
10-09-2012 06:56 AM
dear all
kindly find attached the 3 outputs of the same beam.
In dxf output and ASD output ,the beam is not the same as in robot output.
Please advise.
Any chance for getting the RTD file to test?
Facing some problems too.
What is the RSA template that you used? I'm finding very dificult to find a template that shows all the beam elevation in one sheet (all spans including cantilivers) and sections in the same layout.
Thank You,
Sílvio Gonçalves
Product Support
Jakub.Brozonowicz
Message 2 of 5 (895 Views)
Re: problem( robot to asd)
10-09-2012 07:32 AM in reply to: rodainnajjar1229
What you mean by "not the same beam"?
I see some reinforcement differences but nothing critical in it.
Jakub Brożonowicz
Valued Contributor
rodainnajjar1229
Message 3 of 5 (878 Views)
sirRe: problem( robot to asd)
10-09-2012 11:57 PM in reply to: Jakub.Brozonowicz
dear sir
i mean the reinforcement of beams is different, why ?
,what option i have to do for  best exporting  between robor and asd.
regards
Product Support
Jakub.Brozonowicz
Message 4 of 5 (873 Views)
Re: sirRe: problem( robot to asd)
10-10-2012 12:28 AM in reply to: rodainnajjar1229
Jakub Brożonowicz
Member
Sigo17
Message 5 of 5 (379 Views)
03-14-2013 12:30 PM in reply to: rodainnajjar1229
Thank You,
Sílvio Gonçalves
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
