Hi all, having a problem intergtating the 2 packages.
I select the concrete rc foundation slab in Revit. When I select to send it to Sructural Detailing, I get a message that sais 'The selcted element in not a pile or the element material in not concrete'.
Can it only do it with piles then?
thanks
Simon
Hi Simon,
Wich version of Revit Structure and AutoCAD Structural Detailing do you have?
Can you put your file here please?
Jad
Both are versions 2012. Cant get the file down small enough to attach. Its just a simple pad foundation.
regards
Simon
Hi Simon,
Do you have the Q3 update installed?
Cheers Jad
This is the exstention im using, but having trouble doin a simple pad foundation slab. The extension wont pick it up.
regards
Simon
