I am using English ASD 2013.
But projects are mainly in russian.
I don't want to install Russian version, as I allways try to use only original langualge 🙂
I use Russian profile database and all describtions in tables and descriptors are in Russian.
The issue is with plates.
Whatever I try I cannot find a way to change writing "plate" into Russian, or at least just to put "-" sign istead of this word.
Resulting I have descriptors and tables using russian marking for all profiles except plates.
I would be very grateful if anyone can advice how to get rid of fo "plate".
Solved by Delusory. Go to Solution.
Hey,
Maybe you can tell me, how changed all the names into Russian (or any other language for that mater)? Do you need to edit a file or what?
Hi.
See attached screen shots for what I mean.
I am manually changing the word "plate" to a dash or alternative language.
just in case you're still looking for an easier way of changing the "plate" prefix, go to "Project preferences" and under "General" tab, there is an option named "Nomenclature of plates" at the bottom right corner. Mark the "Overwright prefix" and type in what you would like. It seems to be working very well with the plates created by automatic connections, although I hadn't the chance to test out more.
