AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
PIPES- FLANGES- BOLTS OUT OF STEP
1 REPLY 1
902 Views, 1 Reply
Trying to use Pipes-Flanges connection with DIN pipe size appears the bolts out of step.
I have tried too the Pipes-anchored, and doesn`t appear the holes at the part.
Is there any limitation with this command?
Please help.
Regards
1 REPLY 1
Jakub.Brozonowicz
Could you please try to check if you defined the Radius value correctly (not Diameter)?
Please check the video. http://screencast.com/t/TnOFA3vvXY
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
”Boost
”Tips
