Trying to use Pipes-Flanges connection with DIN pipe size appears the bolts out of step.
I have tried too the Pipes-anchored, and doesn`t appear the holes at the part.
Is there any limitation with this command?
Please help.
Regards
Solved by Jakub.Brozonowicz. Go to Solution.
Could you please try to check if you defined the Radius value correctly (not Diameter)?
Please check the video. http://screencast.com/t/TnOFA3vvXY
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
