AutoCAD Structural Detailing General DIscussion
StefanoPasquini6790
Message 1 of 9 (775 Views)
Personalized bill of material
775 Views, 8 Replies
05-25-2012 10:37 AM
Hello, I need to create a bill of material such as that found in the annex, I tried manytimes but I can not. Some of you can help me?
Could you explain how to use an .xlt excel file as a basis for creating the list of materials?
thanks a lot
Stefano Pasquini
PasProStudio
Structural + Detailing engineers
Hi everyone,
I've resolved with a VBA Macro for Excel, that transform the original BOM in a required one. If someone is interested to resolve the same issue, or a similar one, I can help you, obviously for free!
Greetings
Distinguished Contributor
CristianLANCULESCU1367
Message 2 of 9 (743 Views)
Re: Personalized bill of material
05-29-2012 06:45 AM in reply to: StefanoPasquini6790
If you could translate thoose in English, maybe we can tell you what you can and what you cannot add in you table.
StefanoPasquini6790
Message 3 of 9 (724 Views)
06-04-2012 12:26 AM in reply to: CristianLANCULESCU1367
HI,
i'm sorry for my delay, but i had any problems in last days. Attached below the excel file with the english translation of the required property for my personalized bill of material.
Regard and thank you.
PasProStudio
StefanoPasquini6790
Message 4 of 9 (622 Views)
01-10-2013 02:39 AM in reply to: StefanoPasquini6790
Hi everyone,
Greetings
PasProStudio
Active Member
silvionogueira
Message 5 of 9 (520 Views)
01-22-2013 03:48 AM in reply to: StefanoPasquini6790
Hello
I have the same problem, how did you manage to solve?
StefanoPasquini6790
Message 6 of 9 (510 Views)
01-22-2013 05:40 AM in reply to: silvionogueira
if you can better specify me what you really want to have in your BOM (cut list), I can tell you if I can help you.
Greetings
PasProStudio
Active Member
silvionogueira
Message 7 of 9 (500 Views)
01-22-2013 07:42 AM in reply to: StefanoPasquini6790
What will I use most, is cut list of plates and profiles.
The precise position, quantity, profile, length, weight and area
In short, it's like I show in the appendix, the biggest problem that I am showing is that the table does not interrupt the Rhodope, and when it goes to the second sheet, there will be continued last position of the first sheet should be hidden behind the header
StefanoPasquini6790
Message 8 of 9 (497 Views)
01-22-2013 07:50 AM in reply to: silvionogueira
You can't plot in excel the table? Only in this case I can help you!
PasProStudio
Active Member
silvionogueira
Message 9 of 9 (491 Views)
01-22-2013 08:14 AM in reply to: StefanoPasquini6790
I can export to the format "csv" but header is unformatted
I do not know is to use the template.
Can you explain to me how to use template, export or straight?
When I export to "CSV" is thus, as I show in the Annex.
Anular edições
Alpha
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
