AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Personalized bill of material
8 REPLIES 8
Message 1 of 9
StefanoPasquini6790
1372 Views, 8 Replies
Hello, I need to create a bill of material such as that found in the annex, I tried manytimes but I can not. Some of you can help me?
Could you explain how to use an .xlt excel file as a basis for creating the list of materials?
thanks a lot
Stefano Pasquini
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
8 REPLIES 8
Message 2 of 9
in reply to: StefanoPasquini6790
If you could translate thoose in English, maybe we can tell you what you can and what you cannot add in you table.
Message 3 of 9
StefanoPasquini6790
HI,
i'm sorry for my delay, but i had any problems in last days. Attached below the excel file with the english translation of the required property for my personalized bill of material.
Regard and thank you.
PasProStudio
Message 4 of 9
Hi everyone,
I've resolved with a VBA Macro for Excel, that transform the original BOM in a required one. If someone is interested to resolve the same issue, or a similar one, I can help you, obviously for free!
Greetings
PasProStudio
Message 5 of 9
Hello
I have the same problem, how did you manage to solve?
Message 6 of 9
if you can better specify me what you really want to have in your BOM (cut list), I can tell you if I can help you.
Greetings
PasProStudio
Message 7 of 9
What will I use most, is cut list of plates and profiles.
The precise position, quantity, profile, length, weight and area
In short, it's like I show in the appendix, the biggest problem that I am showing is that the table does not interrupt the Rhodope, and when it goes to the second sheet, there will be continued last position of the first sheet should be hidden behind the header
Message 8 of 9
You can't plot in excel the table? Only in this case I can help you!
PasProStudio
Message 9 of 9
I can export to the format "csv" but header is unformatted
I do not know is to use the template.
Can you explain to me how to use template, export or straight?
When I export to "CSV" is thus, as I show in the Annex.
Anular edições
Alpha
”Boost
”Tips
