AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Parts edition tab does not update to selection ASD 2015
6 REPLIES 6
Priitl220
856 Views, 6 Replies
I select another profile in model, but the Parts Edition tab does not uptate. I need to switch to model tab and back. I do not rememeber this annoyance in ASD 2014.
Is it only me?
Have I forgotten some setting?
ASD 2015 HF WIN 8.1
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
6 REPLIES 6
in reply to: Priitl220
If I have a new model, it doesn't do this. But once I've been working on my model for a couple days it's starts that behavior. I have the 2013 edition and it's behaved that way since I started using it a year ago.
lincannotbe
Same here.
That function works only for couple profiles, plate, etc.
Once I start build up the model further, the function stops working.
This happens in all versions of ASD as far as I remember.
Priitl220
in reply to: lincannotbe
At the moment it started behaving fine, and I cannot tell what is causing it. I am working on same model as previous.
It started once again when I connected second monitor in the middle of ASD session but restarting ASD made it work fine again.
Weird. I do use a 2nd monitor. That'd be strange if that affected it somehow.
Priitl220
For me the problem occurs when I close the default drawing (drawing1.dwg) before I open my project file.
If i start ASD and do not close the deafult file, it works fine.).
KamikonLK
Smiley Happy
Thansk!
It works!
”Boost
”Tips
