AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
parametric sections
3 REPLIES 3
423 Views, 3 Replies
parametric sections
hi every one
i have problem in exporting steel frame from rsd to asd,when i use parametric section like box and export it on asd,asd can't show this section.please help me.
regards
3 REPLIES 3
StefanoPasquini6790
It depend by the differences in section database. The trick to solve this issue is this:
1) save your robot model with another name (for example filename-export.rtd;
2) change in robot the unexported cross section in a database ones not used in the project (for example hea 1000 instead of rectangular 30x50)
3) repeat the point 2 for all the unexported sections using one database section for each type;
4) export the model to asd;
5) change the fake sections creating, in asd user profile module, the correct one.
Good luck and let me know if it work.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
in reply to: StefanoPasquini6790
thanks for your attention
i do this method that you sent for me, but unfortunately again i have problem.please explain it in another method if it's possible.
regards
vanvan11
sorry if i can help with idea to modify profiles in asd after import:) not very great idea
one time when i export from robot to asd (2015v) composite section profiles are inserted only axial line
”Boost
”Tips
