AutoCAD Structural Detailing General DIscussion
Valued Contributor
Priitl220
Message 1 of 8 (618 Views)
Opening ASD 2010 Steel drawing with ASD 2013 - Fatal error
618 Views, 7 Replies
12-17-2012 12:39 AM
Should I be able to open ASD 2010 steel drawing with ASD 2013 version?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Finally it was solution by opening with recover in 2011 and saving there.
Next attempt of opening it in 2013 finishes successfully.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Valued Contributor
lucis29
Message 2 of 8 (613 Views)
Re: Opening ASD 2010 Steel drawing with ASD 2013 - Fatal error
12-17-2012 01:13 AM in reply to: Priitl220
Of course. The other way arround is not possible.
Valued Contributor
Priitl220
Message 3 of 8 (609 Views)
12-17-2012 01:30 AM in reply to: lucis29
Have you tried it yourself?
For me it causes fatal error.  I have tired with two different drawings.
I can not post the drawings, as they contain sensitive information.
And I cannot produce any other sample file, as I do not have ASD 2010 installed.
P.S. The other way around .... was not the question.
Product Support
Jakub.Brozonowicz
Message 4 of 8 (596 Views)
12-17-2012 03:57 AM in reply to: Priitl220
I think sometimes it happens but please try to share the file.
We have abilities to check it closer and possibly fix.
BTW is 2010 version file saved on priintout or model tab?
Jakub Brożonowicz
Valued Contributor
lucis29
Message 5 of 8 (594 Views)
12-17-2012 04:00 AM in reply to: Priitl220
Yes. Off course I've tried. Otherwise I wouldn't have answered.
Try to open the back-up file.
Product Support
Jakub.Brozonowicz
Message 6 of 8 (547 Views)
12-20-2012 08:24 AM in reply to: lucis29
Jakub Brożonowicz
Valued Contributor
lucis29
Message 7 of 8 (522 Views)
12-21-2012 07:59 AM in reply to: Jakub.Brozonowicz
So, that means ASD2011 is the most stable and the best version? I still vote vor ASD2012 as beeing the best until now.
Product Support
Jakub.Brozonowicz
Message 8 of 8 (518 Views)
12-21-2012 08:31 AM in reply to: lucis29
This solution accepted is just incidental - in such case only.
General conclusion about stability is rather unjustified.
But I can confirm that most of all examples are not easy to open in 2013.
Jakub Brożonowicz
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
