I installed Structural Detailing 2012 and when I want visualate the model 3D in Navisworks 2012 it don't seem well because is necessary to install object enabler, but in the page of autodesk there isn't it. When I go to install object enabler of 2011 SD in Navisworks 2012 the program is fail and need be reapired.
Solved by Pawel.Pulak. Go to Solution.
object enabler for ASD 2012 will be available very soon - I will notify you on Monday 2011/05/13
ASD 2012 Object Enabler is already available - it can be downloaded for instance from there:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334440&linkID=10382102
