Hi All,
I am trying to use the Revit formwork link but seems that something goes wrong. Not all elements (It seems to me randomly) are passed to the formwork drawing module. Any suggestion
The Revit "side"
The ASD Formwork "side"
Gabriele, any chance to attach the rvt file?
Hi Jakub,
you will find enclosed here the rtd file causing the problem. In many cases the process end with ASD crash as shown in the image.
Thanks.
I have checked it and I can confirm this problem.
Under investigation.
I don't know exactly what is hapen in your case but I nave experience in the Plant3D export to the REVIT.
In the case of Plant3D in principle I had the same problem, and the solution were revise the analytical view. Because in the structural programs there are two type of views: 3D and analytical. 3D this is what you can view in the display, and analytical it is what you can export and to do calculations. And when you create the beam in first moment the analytical and 3D views it's the same, but if you go to copy, extend, trim and to do any more modification, the analytical view is not the same that 3D. And is necessary usually check if the first coincides with the second. Now I normally modify directly on analytical view and in this case don't have that problem.
Hi All,
Againg on the same problem. If you have a simple wall with a door, the door will be not exported:
Anyway if you change the Heigth of the wall as shown inthe picture.
thanks
I can confirm it.
Sent to analyse.
