AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
No Steel In Base or Projected Views
10 REPLIES 10
Message 1 of 11
herb.cornelius
985 Views, 10 Replies
I have a steel model I created w/ ASD. I made a base & projected views but the steel does not show up. The solids I extruded are there but no steel. Any ideas on how to fix this?
Thanks.
10 REPLIES 10
Message 2 of 11
zcsillag
in reply to: herb.cornelius
Upload file
Regards
Csillag Zoltán
Message 3 of 11
herb.cornelius
in reply to: zcsillag
See attached.
Message 4 of 11
zcsillag
Make group, attach document
Regards
Csillag Zoltán
Message 5 of 11
herb.cornelius
Make a group of what?
Thank you,
Herb Cornelius
225.223.9940
This e-mail and any attached files may contain CB&I (or its
affiliates) confidential and privileged information. This
information is protected by law and/or agreements between CB&I (or
its affiliates) and either you, your employer or any contract
provider with which you or your employer are associated. If you are
not an intended recipient, please contact the sender by reply
e-mail and delete all copies of this e-mail; further, you are
notified that disclosing, copying, distributing or taking any
action in reliance on the contents of this information is strictly
prohibited.
Message 6 of 11
zcsillag
Yes make ASD standard group !
Regards
Csillag Zoltán
Message 7 of 11
zcsillag
Select any profile and make ASD "Standard"group, after attach document ... etc
Regards
Csillag Zoltán
Message 8 of 11
herb.cornelius
I did that. It shows up in the "Edition layout" but that is the only one. And only one group will show at a time. Does it not work in other layouts?
Thank you,
Herb Cornelius
Message 9 of 11
zcsillag
Activate any Layout in ASD Printouts Object Inspector
Go Position tab, right click ... and Add as a block to current printout
Regards
Csillag Zoltán
Message 10 of 11
herb.cornelius
Thank you for your help.
That's a lot of work just to get it to view. It would be much easier (& user friendly) if it just worked like a viewport.
Currently I am the only person in our building (of over 800) using ASD. Most everyone else is using Pro Steel. I don't think I can recommend anyone switch to this. It's too cumbersome, no support (or concern) from AutoDesk and the online help is a joke.
The 3D model is pretty to look at, but is not practical for construction drawings. I'll just go back to regular AutoCad.
Message 11 of 11
zcsillag
”Boost
”Tips
