I have a steel model I created w/ ASD. I made a base & projected views but the steel does not show up. The solids I extruded are there but no steel. Any ideas on how to fix this?
Thanks.
I did that. It shows up in the "Edition layout" but that is the only one. And only one group will show at a time. Does it not work in other layouts?
Thank you,
Herb Cornelius
Activate any Layout in ASD Printouts Object Inspector
Go Position tab, right click ... and Add as a block to current printout
Thank you for your help.
That's a lot of work just to get it to view. It would be much easier (& user friendly) if it just worked like a viewport.
Currently I am the only person in our building (of over 800) using ASD. Most everyone else is using Pro Steel. I don't think I can recommend anyone switch to this. It's too cumbersome, no support (or concern) from AutoDesk and the online help is a joke.
The 3D model is pretty to look at, but is not practical for construction drawings. I'll just go back to regular AutoCad.
Sign this and Advance Steel ...
http://www.change.org/petitions/autodesk-where-advance-steel-and-concrete-from-building-design-suite
