AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Navisworks integration
6 REPLIES 6
829 Views, 6 Replies
 now I probe to open one Structural Detailing file with Navisworks, and the properties of elements don't view. (I was installed the object enabler of Structural),
Is normal?
6 REPLIES 6
lee.mullin
Can you attach a sample file?
Which version of Structural Detailing and Navisworks are installed?
In Navisworks can you take a screenshot of the Options > File Readers > DWG/DXF/SAT and upload this please?
Does this work when you export an NWC from Structural detailing ( if the exporter is installed then 'NWCOUT')
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
in reply to: lee.mullin
The version of both products is 2012.
This is the screen capture of configuration of the dwg reader:
And attach the nwc file exported with the NWCOUT command, and the dwg file of the structure.
Sorry for the various post, is because the foro don't accept files biger 1,5Mb
lee.mullin
Everything seems fine with the options, can you upload a screenshot of the properties of an object in AutoCAD and the equivalent item in Navisworks with the properties window open?
I assume you have the 2012 AutoCAD Structural Detailing Object enabler relevant for the machine, i.e. you need 32 bit on 32 bit and 64 bit on 64 bit.
Lee Mullin
Autodesk Ltd.
Hello, after one year I see that the 2013 release of Structural Detailing and Navisworks, continue without properties integration.
 I want to see type of each steel member, and position in Navisworks, it's posible?
”Boost
”Tips
