AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Minimum radius for copes
2 REPLIES 2
haydenwse
2108 Views, 2 Replies
AISC and AWS require that beams be coped notch free with a minimum 1/2" radius in the cope cuts but the macros all trim the notches with a square cut.  What is the best way to modify these cuts to have the required radius?
2 REPLIES 2
If I understand the shape of this treatment is probably only fit a polyline could help you with this.
Jakub Brożonowicz
Global Product Support
The above response did not answer my question.  I need a way to cope the flanges of beams at single shear plate and bolted clip angle connections.  The standard macro’s just fit the flanges with a square corner but the US codes do not allow this square re-entrant corner.  The fit must have a minimum ½” radius.  This means that I will need to go in and change each one by hand after creating the connections.  Is there a better way?
”Boost
”Tips
