AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Making slight changes to connections
1 REPLY 1
danielledew
644 Views, 1 Reply
Hi.
Something I've encountered while working with ASD is that you cannot make slight modifications to a connection without it defaulting back to how it was. For example, there is not option to give a plate a horizontal offset in a connection, so when I go and manually move a plate after placing the connection it will move and look fine, until I either update or modify the connection.
I understand why it does this, but our South African standards aren't fully catered for in ASD, so then the easiest workaround is to create a connection and then modify it to suite our standards.
Does anyone perhaps know if there's a way to explode a connection so that these minor changes will be possible?
Thanks!
1 REPLY 1
Tony_Gibbs
in reply to: danielledew
You can try to save the connection after you make the changes then It shouldn't default back
”Boost
”Tips
