I used the base plate macro and made a elongated cap plate with holes. It seems to work ok on one column line, but It needs it to mirrored on the opposite column line. It's not working, what am I doing wrong. HELP.
Solved by Jakub.Brozonowicz. Go to Solution.
I am using the the base plate macro. I am trying to have a 2-hole on 1-side 6" apart and at 90 deg. 2-more holes 6" apart 18"x18"x1 1/4" PL. I got it to work one side but i couldn't on the 90 deg. side. Thanks
from what I have seen, ASD does not play well with the mirror command
If I can't use this base plate macro for this particular plate. Could I use the plate macro and add holes where I need them? If so, How would this work.
Do you have any chance to show it please?
